How does the top mount attach to dash?
Just clipped in very sturdy if i remember. Dont use it any more as i dont need it in my kombi
CarPlay is an aspect of app connect that replicates the phone screen on the radio screen and let's you run apps and stuff by touching the radio screenhuh......what's carplay? Do I have it in my kombi?![]()
Does the phone grip adjust, i have an iphone 6S but always in a case so its a bit bigger than standard phone, do you think it would fit ??
I returned mine as I found the 6s in a silicone case would slowly slip down as you were driving. Also, last week there was an almighty crack as I was driving and the top half came away, I'm wondering if it was dash expansion, it was a nice sunny day. Returned to Apple Store with no issues. Ordered a Brodit to replace it.Does the phone grip adjust, i have an iphone 6S but always in a case so its a bit bigger than standard phone, do you think it would fit ??
Can you still operate the Hazard and windscreen heater buttons with this mount fitted, any pics would be appreciated.Ill grab a few photos later, I've got both the Brodit mounts, the top one is for my auxiliary lighting and the lower one for my iPhone next to the USB socket for the carp play.
Both work well but I ned to try and move the heated windscreen & hazard switch to the other side with the dif lock switch if its doable.
Thanks @Moose - order placed today using the code.use the code BRODITSUMMER (all upper case) for 20% off valid until 31/7/17
Yeah, that does make sense thanks. I suppose I'm not used to not having my phone close by on a cradle. I'll get used to Appleplay. I've indeed got the builders dash. And I'm using my van as a van. It's in for mods soon, so watch this space......I take it you don’t have a comfort dash? If that’s the case I used to put my phone on the small shelf by the dash USB which is enabled for carplay.
I just upgraded to the wider centre console and it’s migrated into the pocket on the top.
Both positions keep the lead quite short.
I hope that makes sense?
