Haven’t had my seats or slim units fitted yet, soon as it’s in that will be extended and relocatedOdd choice of position for the panel.
Thats a convenient user location for the controller.....
Had a van in with a Webasto controller positioned there the other day, not exactly convenient. looks Like the installer couldn’t be bothered, also I suggest changing that vent to prevent debris finding its way in and downThats a convenient user location for the controller.....I hope they have not set it to use the stat on the controller
I am forever telling people that without an external temp sensor the temp that the heater sees is the temp of the air entering the heater not the temp that any controller sees and indicates at the mounting height. There can be 10 or more degrees difference between the two.
post: 354254:-
Try setting it a lot lower 8/9 degrees say - the air entering the heater will still be attempting to reach 17 degrees at floor level when it has started cooking you at mid height in the van.
You can get a remote temp sensor which you can position wherever you want. I've got mine at the same level as my exploria bed.....its almost invisible against the carpet wallI know the pu5 is much more simple - just literally a temp knob right? How does it know when to switch on or off, does it have a built in temp sensor?
