Think of it like trying to fill a bucket, that has a hole in it. ( The Battery )
Your solar charge controller is trying to fill the bucket, as fast as it can....this will be a function of the panel and charge controller.... 6A per 100w as a rough guess.
The fridge is the hole draining water or power.
The voltage will rise gradually as the SOC increases due to the potential difference of the charge source and battery voltage... and internal resistance.
The only way to see that immediate increase in voltage is to have a charge source that's higher than the battery can absorb.... ie 15A.
So.. just leave the solar connected... it may take 10 -24 or more hours to charge the battery.
A few hours just wont do it... (unless you have a higher charge capacity like 20A or similar)
edit:
thats why you will see that instant rise in voltage from the van engine running from your DC-DC/VSR. . . . . there is much more power available to charge the battery so the voltage will show high from the start.
The water pressure (voltage) will overcome the leak in the buck and the fill rate (current) can fill the buck faster than it is draining.
edit:
