Any plumbers out there please?
Ever since we moved into this house the hot water system has had low pressure to the hot water taps. We have a water tank in the loft feeding a 120L electric immersion cylinder just below it in a cupboard on the second floor and that provides hot water to the shower (via a pump which gives a good flow) and sinks in the bathroom, downstairs toilet and kitchen which all suffer from poor flow on the hot side but it’s the kitchen tap that’s the real problem (in terms of ‘pipework’ the kitchen is furthest way from the cylinder)
A few years ago, we had a new copper cylinder fitted which is when the problem below started. Since then we have had three different mixer taps (all supposedly designed for low pressure systems). The latest is a cheapo (IIRC £80 Ikea) but the previous two were more expensive from Franke and Grohe and all of them had the same issue. As said above, the flow from the hot side is poor, so poor that sometimes when we turn it on, no hot water comes out. At other times, it takes a couple of seconds to start but more often starts straight away. On the occasions when it doesn’t start at all, turning the downstairs toilet tap on and off gets it going.
I’ve been told that installing an ‘unvented hot water cylinder’ is the answer to the problem and have done a bit of research on line which seems to support that but any advice from people on here would also be much appreciated. As far as I can see, the two main drawbacks are:
- How much hot water the things can get through (as it comes out at mains pressure) but a larger cylinder might sort that out.
- I have also read that they should be inspected annually by a suitably qualified plumber which would be an ongoing cost but might also give problems when you;ve got to find somebody to actually do it.
