Can I ask, is it a big job for SCR to fit these shark fin aerials. Does the fin need mounting front or rear on the roof. I see the kit retails at £150. Is it a good upgrade. What sort of cost am I looking at fitted. Cheers.Had mine fitted by Skipton Car Radio as well.
It’s straightforward enough, you just have to be patient to ensure you don’t break the mirror-cover clips. Or you can check the rear of the h/u for the DAB plug / check the door connections behind the door-card are good. Click on the tags for threads relating to it.Dab has never been perfect, how do I easily remove passenger cover to check.
App-Connect has can be authorised by third-parties remotely nowadays. With Apple, you have to upgrade your USB port, but I’m not sure about Android.Also can app connect be added or have I to upgrade head unit, only really miss android auto so any cheap options about to upgrade too.
Your DAB antenna should be in the mirror housing, so it’s unlikely that pop-top fitting is causing havoc.Hi,
I've got a converted t6(t28 2015 camper king conversion) and it has an awful digital radio signal. Signal keeps periodically dropping (drops out for 30s every 120s on average) even when parked in a built up area. Totally different experience to my 2016 Ford C-max which never drops despite being driven in the same areas. I've only owned the van for the last six months so not sure if this is something I should expect from a T6 or if they butchered the aerial fitting the pop top. Any ideas gratefully received.
Thanks!
I had the same when I put LEDs in the DRL, it would drop signal asi reversed out of the garage for some reason. If the headlights were on (DRLs off) no issue. Swapped back to normal DRL bulbs and all ok. I’ve since swapped to aftermarket lights so I can see where I’m going and Ilkley Car Audio fitted a shark fin aerial which improved DAB massivelyAfter a bit of help, please. Have changed over the drls on my t6 which has H4 headlamps. The new lamps P21 LEDS are causing some stations on the dab radio to drop out, but not all of them. I spoke to the company who supplied the lamps and they sent a replacement set but they do the same. I have also tried the magnetic cable surrounds with no luck. As anybody any more ideas please?
Cheers Lee, I'll have a read.![]()
T6 Aerials, GPS, DAB, FM/AM, GSM - How I Did It -
T6 Aerials, GPS, DAB, FM/AM, GSM - How I Did It - Taken from a recent thread about poor DAB reception on the head units, and an attempt to help out a fellow member . . . . . . i though id post this here. All the antennas for the T6 are located in the side wing mirrors. The left contains...www.t6forum.com
Only thing I've change electrical recently is some Thq V2 headlights. Could they be blocking the signal?Cheers Lee, I'll have a read.
Quite possibly yes. The LED DRL could be having an impact. If you’ve got LED headlight bulbs in, that could have an impact too.Only thing I've change electrical recently is some Thq V2 headlights. Could they be blocking the signal?
No led apart from the running lights. Tried turning I the radio and then only the lights and that made no difference. Weird as I've han no problem for 2 years before nowQuite possibly yes. The LED DRL could be having an impact. If you’ve got LED headlight bulbs in, that could have an impact too.
If you run some specific LEDs, they’re electrically ‘noisy’ and that can wipe out the DAB signal. Similar to the alternator whine or interference from the coil you used to get on old car radios.Only thing I've change electrical recently is some Thq V2 headlights. Could they be blocking the signal?
