im not a fan of those quick release connector's.@Dellmassive - per above you were massively helpful - I have ploughed my way through your post - just got one query - and apols if really dumb question
Attached are a couple of pics from my leisure battery - theory is just connect crocodile clips running from the controller to the terminals on leisure battery - i.e. the gold terminals?? But per pics attached terminals seem to have the silver clamp around them - so now a little unsure..? Or have I got it completely wrong!?
There's some really good prices on Dokio ones at the mo - but appreciate needs to be fused, so would likely order something like the Renogy just to eliminate any risk!
Thanks in advance, Phil.
the red and blue things.
personally i would replace those for better bolt on battery terminals,
or unbolt the battery turrets, then use bolt down ring terminals.. .
but looks like its close to a seat? - is so id get a cover for the terminals or a full battery cover.
you can use the solar panel clamp ons.
but if the battery is under the seat, you may be better off fitting a short quick-connect cable, so its plug and play.
maybe like this with a fuse?
or this?
or you can connect any of the above via your 12v sub fuse box.
