come join the club -
VIP Membership | VW T6 Forum - The Dedicated VW Transporter T6 Forum
for now:
the mirror section does have a spring loaded part in case it is hit by an object . . . . . Try grabbing hold of the main body and try to rotate back to its normal location.
and of course try the electrical part folding in/out
quick look here -- >
2 - Insulation
3 - Bolts
q Qty. 3
q 6 Nm
4 - Warning lamps for lane change assist
q Removing and installing
5 - Connectors
6 - Mirror glass
7 - Housing frame
8 - Bolt
q 2 Nm
9 - Bolts
q Qty. 2
q 2 Nm
10 - Mirror trim
11 - Adjuster unit
12 - TV module
13 - Aerial module
14 - Mirror cover
Removing
– Remove front door trim
– Disconnect earth wire and connectors -3- from subframe.
Note
Depending on the equipment level, other connectors and earth wires may be present and need to be disconnected prior to the removal.
– Remove bolts -2-.
– Remove exterior mirror -1- from door.
– Pull out cable through hole in door.
Installing
Install in reverse order, but note the following:
