Hi
I have a Vitoman 1500 flashspeed powerstation. I want to be able to charge it via my leisure batteries using the 400w solar input (Anderson) rather than the slow 200w car cigarette input which will probably melt everything inc my van.
Prob is the solar input voltage has to be an unusual high 30-60volt so I need to up my 12v to this. I'm not expert so can anyone tell me if the following item will do this job ?
I don't want to blow my new expensive toy
Product Name: 12V to 48V 8A Step-up DC-DC Converter; Input range: 10-25V DC
Features
1. 100% full power and stable current output
2. 100% Imported components
3. Wide input voltage from 10-25Vdc
4. 100% waterproof and anti-shock protection, Ultra compact size, light weight
5. Industry grade DC12V to DC48V step-up converter, efficiency up to 96%
6. Certificates: CE/RoHS
7. Waterproof level: IP68
8. Die-cast aluminum shell, epoxy potting, Cooling by free air convection,
9. Protections: Over-current, Over-voltage, Over-temperature and Over-load Auto-recovery when device is back to normal operating
10. Non-Isolated Module
11. 1 year , life time up to 100,000 hours.
Specifications
Input rated voltage: 12V DC
Input voltage range: 10-25V DC
Efficiency: 97% (half load) ; 96% (full load)
Output voltage: 48V DC
Output current: 8 Amps
Output rated power: 384 W
Output peak power: 125%
Voltage regulation: < 1%
Load regulation: < 2%
Ripple(full load test): < 180mV
No-load current: < 30mA
Working Temperature: -40°c ~ +80°c
Waterproof rating: IP 68
Protections: Over-load, Over-current, Over-temperature, Over-voltage
Machine size: 100*80*39mm
N. Weight: 535g
Cooling way: Free air convection
Certifications: CE, RoHS
Features
Specifications
N. Weight: 535g
