Fluke 123Side issue @Robert but what’s the meter you’re using with the mini oscilloscope display? Looks very useful
Ok I'll just sit down and breathe deeplyFluke 123
Fluke 123B 2-Channel Industrial ScopeMeter 20MHz Handheld Oscilloscope
Three tools in one - oscilloscope, digital multimeter and recorder Dual-channel oscilloscope with 20MHz bandwidth Fluke Connect enabledwww.tester.co.uk
To whet appetite....Ok I'll just sit down and breathe deeplyMaybe I'll manage without
So, moving on, I would recommend that anyone with these puddle lights reconsider the way they are connected to their van. I will be changing mine to the courtesy lighting circuit as soon as I can.
Beautiful2 weeks after fitting the v2 puddle & red "open door" warning lights as per @saxoboy 's well written instructions to the door lock/unlock circuit, all is still well and working as they should.
No error codes, no weird goings on.
Swapped the halogen bulb with the supplied LED version on the red warning light and jobs a gud 'un
The door card was easier to cut with a Stanley knife after it was heated gently with a hot air gun to soften it up.
Well chuffed with how they look
Did you get your wiring sorted @Andysmee ?
Yes, I moved all of mine onto the courtesy circuit2 weeks after fitting the v2 puddle & red "open door" warning lights as per @saxoboy 's well written instructions to the door lock/unlock circuit, all is still well and working as they should.
Here's a matching plot of voltage threshold of a VW OEM load area roof LED light. The illuminance values are not calibrated ones - just had a cell phone 0.5 metres apart + an Android app "Keuwlsoft - Light Sensor Counter".My final conclusion is that only puddle lamps/lights with verified voltage threshold of at least 6V should be used.
