For what it's worth, my two pennies have used the system for the last 7 months.
On first fill there were problems which took a week to resolve, whilst a separate issue the pipes too and from the heater have to be unkinked, not deformed, not squashed a little oval, just the right length and ideally protected from any prevailing wind OR the heater will cut out due to incorrect air fuel ratios. After some tinkering it's been all fine since that first week except on Skye with huge 'blow tents away' type winds when it cut out a couple of times but started right back up again.
The other first fill problem was also air/fuel ratio specific and was down to the tank not filling to 100% but to 80%, air is trapped in the void and until the system burned through it and almost a tank of gas, all £13 worth ! the hob had flickering yellow tips to the flame indicating the air/fuel mix wasn't right.
The fix was, check, adjust and reroute the heater pipes and get pure gas in the tank by using it and refilling.
Propex customer service were excellent, we must have phoned them half a dozen times, they knew their stuff and I recommend the system to anyone.
