I'm pretty relentless when it comes to researching products online and reading as much as possible on this forum. But, after fitting a Rusty Lee Swivel base I wanted to share what I've found which I don't think I was entirely expecting -
1) Added height. It's fairly obvious they will add some height but my advice is to consider whether you will be comfortable with approximately 30mm additional height because it really does make a big difference.
2) Stability. They are well made but the physics at play of a plate which is suspended around a central pivot means they flex, and this makes the seat less stable than before, kind of bouncy front to back and left to right.
For me and my other half the height is a problem, so much so I'm now looking into lowered seat bases (glad I don't have a leisure battery). The wobble seems unavoidable with a Swivel base. It's not too bad when sat in it driving, but move the seat around and when empty it jiggles.
Just thought I'd share in case, like me, you are taken in by the various videos and product briefs that the Rusty Lee swivels are the best going. I'm sure they are great but generally speaking it appears as though a swivel base does come with some compromises.
Hope this helps others
