Hi,
There’s been tons of thread about pulling one way or another. And I’ve had a van that has been sensitive to road camber for three years now, which has just become part of driving the van.
Summary:
- pulled with road camber before subframe dropped
- pulled after subframe dropped and replaced
- struts totally replaced (upgraded shocks, drop links, top mounts / bearings etc)
- arb bushes replaced
- arms checked and all bushes good
- engine mount replaced
- new tyres and wheels
- three alignments (one before subframe dropped, one after, one after new suspension and ride height)
- tried swapping front tyres
- three alignments all in green and told all good by three different shops
The result has always been the same. Most of our roads have heavy camber, and it results in the van wanting to naturally fall into the gutter. It results in needing to have the wheel always slightly pulled to the right to drive straight.
Find a road that’s 100% flat, van drives straight.
Find a road with caber falling away to right, van falls to the right.
I’ve been told it ‘could’ be the tyres, and the size of them causing it (275’s). I’m not sure I believe that.
Has anyone had the same issue and found a solution? I’ve checked subframe bolts too and I daren’t try and pull them up - they are already very secure and I do not want to risk snapping them. Another post on there suggested swinging on them to pull them up more! I don’t like that idea!
From a lot of posts it seems a lot of people have the same problem. And some have had t6’s pull from new. Others never have a pull and straight as it goes.
It’s an odd one. Surely there is a way to stop the van from being so sensitive to road camber and falling into whichever way it goes?
Cheers.
Summary:
Cheers.
