Puzzling Parkpilot (sensor) fault
LambethBoy
204 DSG 4Motion
VCDS User
Try to be brief.
driving around normally, went to back into a space, loud tone in cab, parking light flashing on button and "parkpilot not currently available" on discovery media screen, and no rear view camera available either.
Got home, plugged in vcds, (see error codes) cleared them, started van, seemed all fine put into reverse, still fine, had rear view camera on screen, then same noise and message on screen.
Plugged vcds in again same errors.
my confusion is that it has shown two sensor errors from first check?
Is it possible to get two at once with nothing being a problem previously, as i did a vcds check a week previous for another issue, and it was not there.
I have switched the Front left parking aid sensor with the front right parking aid sensor as that one is not showing a fault and I’m still getting the same error codes in the same position, could this be a wiring issue?
@mmi / @Dellmassive i think I’ve seen you guys deal with this before somewhere??
thanks in advance.:thumbsup:
Edit. All wiring from main connector socket to sensors tested and fine..
Put it all back together and it all seems to be working ok???
Will wait and see if it happens again??:cautious:
  • Parking Sensors.txt
Reactions: mmi
New sensord are very trouble some. New caddy is dreadful for these failing all over. VW know about it and keep it quiet.
