This is a common issue with camper conversions as the weight over and behind the rear axle increases the front gets light and steering feels less responsive , Wheel spin is worse because as you accelerate more weight transfers to the rear and their simply isn't enough weight on the front axle to offer traction .Before I take it into the dealers so they can advise for £96/hour (!!) ...
Problem, light steering at times, wet and uphill worst with traction control kicking in when at worst (twice in last week) versus a handful of times in previous T6 over nearly 3 years - visually less of an issue for me but the front arch gap appears to be larger than normal.
T28 converted to campervan, see first post for specifics.
Comments welcome :
Happy to explain how to measure the car s rake so we can see how much we need to move things around ?
OK thats a problem a brand new unmolested van should be 40 mm lower front to the rear ( Rake angle )
Cheapest solution would be fit a standard set of T 32 rear springs , easier to do than the front ( he says tongue in cheek ) and easier to find . Not sure if i have any, ill check for you though . This way the ride could be acceptable ;lowering the front with std shocks will affect comfort
Okay if I knew what the T32 rear springs were (part number, colour bands) I could get buy them and certainly take that option.
I've been reading a lot of posts on here and have found that the Eibach 30mm lowering springs don't seem to drop the rear 30mm, most posters on here have said the back sits higher, I was about to buy these just now when I saw your reply - my thinking that lowering in this manner would drop the front 30mm and I'd get 10 or 20mm drop on the back, remembering I've a converted campervan I was thinking that would do the trick. That would hopefully leave me with a 15/20mm rake, would that work or is it a non goer? I'd like to drop the front some if I could. I'm on 16" Devonports and the 30mm drop seems a fairly common mod many people do.
I'm waiting to get this sorted before I head up to the hills for some winter 'sport', I'm kind of budgeting £500 tops if that expands the options any.
I've been reading a lot of posts on here and have found that the Eibach 30mm lowering springs don't seem to drop the rear 30mm, most posters on here have said the back sits higher, I was about to buy these just now when I saw your reply - my thinking that lowering in this manner would drop the front 30mm and I'd get 10 or 20mm drop on the back, remembering I've a converted campervan I was thinking that would do the trick. That would hopefully leave me with a 15/20mm rake, would that work or is it a non goer? I'd like to drop the front some if I could. I'm on 16" and the 30mm drop seems a fairly common mod many people do.
