Hi all.
I get an annoying driver's side window shake/rattle when the window is down just slightly for ventilation - like about a 1-2cm gap. I seem to get similar on the passenger side but not quite as bad (but that could be down to proximity). It disappears when the gap is about 3coms or more.
I'm wondering if it is a common issue - also wondering if it is actually being caused by the way I have fitted my wind deflectors.
I know I could check if it's the wind deflectors simply by removing them but I thought I'd check here first. They are the Climair type by the way - bought after seeing them recommended here, although I was surprised to see that they needed a locating screw as any wind deflectors I've had on cars were Heko and they didn't need screws. I mention this as if it is the wind deflector causing the issue I will likely have to reposition somehow which would involve drilling another hole...
Thanks.
Thanks.
