Hi,
I got a bit excited whilst trolling eBay.
I’m after car play for my T6 and saw the Rcd330+ so for the price decided I was having it without looking into it very much.
Anyway it’s arrived and found the connections to be the same quadlock unit but the pin layout is different anybody know of a wiring adaptor to change as google searches are coming up with nothing.
It’s all changed since I wired a radio all we’re just basic wiring with out all the can bus bits. I’m assuming as you can buy aftermarket radios that will fit the T5 & T6 it’s just a case of re positioning the wires to the correct places?
There is three other connections as well which I’m assuming are the Fm Ariel/ DAB / usb? The fitting is the same on one but a different fastener so have found popping an insert out makes that fit ok.
