Thanks for the replyI guess anything is possible. You will need to get the QR feet moved backwards, or add a new set in behind the front set. That way you can have them in the front slots, or place the front feet in the back set of the normal place, then the back feet of the seat will clip into the newly added ones.
If that makes sense.
?I'd imagine it would need to be the triple bench seat as they have the seat belts in the seats and not on the c pillars
I have a triple bench seat, it is only the centre seat that has the belt built into the seat. The two outer positions have the belts mounted on the C-pillar.
This is also the same for the 2+1 and the 1+1+1.
Hi although this was a few years back, wondering if you did this and if so how you overcame the seatbelt problem… I had the same thought of moving them back 400mm cheersApologies in advance if this has already been asked, is it feasible to re-position the 2nd row seats 18 inches to 2 feet towards the rear of the van. Thanks
Hi Shaun, I purchased the seat belt kit for the 3rd Row.Hi although this was a few years back, wondering if you did this and if so how you overcame the seatbelt problem… I had the same thought of moving them back 400mm cheers
Hi thanks. I’m sure I can move mine back 400mm and the original seat belts on the c pillar will work.. then I can still fit a fortywinks swb bed… fingers crossedHi Shaun, I purchased the seat belt kit for the 3rd Row.
Sounds good, good luckHi thanks. I’m sure I can move mine back 400mm and the original seat belts on the c pillar will work.. then I can still fit a fortywinks swb bed… fingers crossed
Sorry for resurrecting an old thread but can the Kombi 2+1 rear seats(T6.1) be moved to the rear position too or is it just the triple bench?Is it a triple bench? In which case there are the markings in the floor, to be able to move it back to a ‘factory position’, the same as a shuttle 3rd row.
