Hi guys, I’m trying to replace the rear engine mount in my van with CXGB engine code. Can anyone confirm if all the rear engine mounts are the same ? All the ones I see do not list engine code CXGB suitable. Also has anybody fitted one and if so how did you go about it ? Was it easy ? My engine rattles on initial start up at the rear drivers side. It only does it as the engine is igniting. I’m going to replace the drivers top side mount as well. I had to replace the front mount last year at 60,000 miles as it had split. Many thanks folks.
