I will attach a photo tommorrow. And try and find link to velcro. I did find the link to velcro on here originally as that's where I got idea from.Be interesting to see pics and a link to the Velcro you used
Did you put the junction box to the front? Also did you seal all of the way accross the front edge? I have the same job to do on the same panel in the next couple of weeks!
Also, I've been lurking for a while but this is my first post
I’ve been looking to get this same panel. Any hints or tips from your experience of fitting it?
I only took picture of boot closed from that angle as you cant really see the wires from behind or from the other side.Be interesting to see pics and a link to the Velcro you used
Very interesting. I see you have a pop top installed. Is the top of your roof ridged like the standard van roof or is it flat? Just wondering if this would work for a standard van roof or if the airflow through the ridges would cause enough pressure to pull the panel off...I’d prefer not to drill holes in my roof if I don’t have to.I only took picture of boot closed from that angle as you cant really see the wires from behind or from the other side.
Here's a link to the velcro. Its been on roof for 2 years now and never had a problem. I left gaps so the panel wont overheat, water and air can get in and out aswell. Was a nervous first journey as day after we fitted we left for France for 2 weeks.
Velcro Brand Black Heavy Duty Stick-On Tape 5m x 50mm - Screwfix
Order online at Screwfix.com. Heavy duty, weatherproof tape with moulded plastic hook feature and high strength adhesive. Can be cut to length and is reusable. Ideal for the most demanding of indoor and outdoor projects. FREE next day delivery available, free collection in 1 minute.www.screwfix.com
Mine is a flat roof but I honestly dont think wind would pull it off. You wouldn't believe how strong it is. I was the same I didnt want to drill roof and thought the velcro idea from someone else on here was a great idea.Very interesting. I see you have a pop top installed. Is the top of your roof ridged like the standard van roof or is it flat? Just wondering if this would work for a standard van roof or if the airflow through the ridges would cause enough pressure to pull the panel off...I’d prefer not to drill holes in my roof if I don’t have to.
Wouldnt this connect the +ve of the panel to the -ve of the MPPT? Is that right?
