Thanks, Deaky,
That's very helpful indeed. I'd measure myself, only that our California Beach
(T6.1 - 3 seat bench - Australia Edition, as Ocean won't be released with sliding door on the wrong side - noncompliant) only arrive in Jan/Feb 2021.
So a tray 1,000mm wide internal dimension
(1,040mm external) will work!! now just to configure the max load length)
Trying to configure a rear cargo slide tray
(internal L 1,200 x W 1,000mm), to accommodate my camping crates
(L 600 x W 400 x H 240mm), and trying to work out if the bench is moved forward, will there be enough space for our Dometic/Waeco CFX 95DZ fridge
(L 962 x W 530 x H 472mm), and still have enough legroom
(between bench and fridge. fridge can also be used as a legrest) for the two rear passengers
(our kids).
In summary from the rear tailgate; Sliding Tray
(under multiflexboard), then 3-seater bench, then fridge.
The European trays are not available in Australia, hence a custom build. Not a problem as there are a ton of fabricators making similar trays for the building industry for the back of Utes
(Utility vehicles, double cab Toyota, Ford etc. pickup truck)
How long are the rails/tracks?
Do you think this will work or should I limit ther tray to 1x1m max. I see the Swiss version 'CaliXtension' is max 1m deep
Again, many thanks again for your help and sharing.
Much appreciated
Morné
