Address 08: Auto HVAC (J255) 9480753 - Control/Display Unit for Rear Climatronic B10AA 31 [008] - No Signal Not much information available for this; it would seem to be a temporary communication loss with the rear climatronic unit.
www.t6forum.com
A few engine related fault codes listed here --->
VW DTC List
Admin welcome to relocate.
EDIT:
Address 09: Cent. Elect. (J519)
03224 - Play Protection Active
Sometimes referred as child lock activated. Actually I've seen when door lock was frozen and couldn't unlock nor lock from remote (was just driver door, others ok).
03303 - Response Closing Status of Rear Left Door - 008 - Implausible Signal - Intermittent
03304 - Response Closing Status of Rear Right Door - 008 - Implausible Signal - Intermittent
As of Feb-2021 it seems that ODIS is ignoring these faults not being "real" faults. I had van serviced with fresh both faults, however I was informed that ODIS didn't show neither of them. Unfortunately due to Covid-19 restrictions I couldn't accompany technician.
Address 10: Park/Steer Assist (J446)
1078804 - Rear Left Parking Aid Sensor - B1076 14 [008] -- Open or Short to Ground
1078833 - Rear Left Parking Aid Sensor - B1076 31 [009] -- No Signal
1079060 - Center Rear Left Parking Aid Sensor - B1077 14 [008], [009] -- Open or Short to Ground
1079089 - Center Rear Left Parking Aid Sensor - B1077 31 [009]-- No Signal
1079316 - Center Rear Right Parking Aid Sensor - B1078 14 [008] -- Open or Short to Ground
1079337 - Center Rear Right Parking Aid Sensor - B1078 29 [008] -- Signal Implausible
1079345 - Center Rear Right Parking Aid Sensor - B1078 31 [008] -- No Signal
1079572 - Rear Right Parking Aid Sensor - B1079 14 [008], [009] -- Open or Short to Ground
1079601 - Rear Right Parking Aid Sensor - B1079 31 [008] -- No Signal
1111826 - Front Left Parking Aid Sensor - B10F7 12 [009] -- Short to Plus
1111828 - Front Left Parking Aid Sensor - B10F7 14 [008], [009] -- Open or Short to Ground
1112084 - Front Left Center Parking Aid Sensor - B10F8 14 [009] -- Open or Short to Ground
1112340 - Front Right Center Parking Aid Sensor - B10F9 14 [009] -- Open or Short to Ground
1112596 - Front Right Parking Aid Sensor - B10FA 14 [009] -- Open or Short to Ground
The anatomy of the fault code
Fault codes can be a wealth of information! .. and we sometimes overlooked this. Here is a basic guide to understand some of the components of the fault code. We can break down the fault code into the following parts: - The fault code numbers - The fault code description - The freeze...
forums.ross-tech.com
