Hi no didn’t have any further luck. We mostly notice it when we’re parked on a hill and try to put the belts on. We have to move the van to somewhere more level then it’s ok again!!did you solve this? I've been struggling with mine every now and again for the last year or so. Seems all 3 dont release every now and again. let a little retract back in, and you just have less to play with!
1. YesHas anyone removed this bearing? or have any information on the consequences?
I am on my second Reimo seatbelt because they keep locking up irretrievably. I made the mistake first time round of taking off the other side of the mechanism which is the bloody great spring!!! If you do this count yours fingers then throw the mess in the bin and order a new belt from CMC!Right, I got fed up and dismantled the seat. There is a bearing which locks the belt if it's not completely level, see photos. It seems to be more sensitive to forward and backward than side to side but I think the easiest way to release the belt would be to tilt the seat forward slightly. The belt mechanism needs to be perfectly vertical to release properly, and the seat sits leaning naturally slightly backwards. I'm in two minds. It is removable, and doesn't affect the belt locking in an accident. I can only assume its to ensure the seat its properly in place. Modifying seat belts has alarm bells all over it though! View attachment 160714
Is there any rotational adjustment?Right, I got fed up and dismantled the seat. There is a bearing which locks the belt if it's not completely level, see photos. It seems to be more sensitive to forward and backward than side to side but I think the easiest way to release the belt would be to tilt the seat forward slightly. The belt mechanism needs to be perfectly vertical to release properly, and the seat sits leaning naturally slightly backwards. I'm in two minds. It is removable, and doesn't affect the belt locking in an accident. I can only assume its to ensure the seat its properly in place. Modifying seat belts has alarm bells all over it though! View attachment 160714
I know I’m resurrecting an old thread here @monkeytrumpet but how the heck did you get to the seatbelt? My belts are sticking and not snapping back into place. I’ve 2 brand new complete Reimo replacements but went to take the seat cover off to do this and got completely stuck!Right, I got fed up and dismantled the seat. There is a bearing which locks the belt if it's not completely level, see photos. It seems to be more sensitive to forward and backward than side to side but I think the easiest way to release the belt would be to tilt the seat forward slightly. The belt mechanism needs to be perfectly vertical to release properly, and the seat sits leaning naturally slightly backwards. I'm in two minds. It is removable, and doesn't affect the belt locking in an accident. I can only assume its to ensure the seat its properly in place. Modifying seat belts has alarm bells all over it though! View attachment 160714
