MattsT619!
Can you supply a Reimo rail that is curved to follow the rear window and front door but also curved to follow the van side front to back to save me having to push the rail onto the van side to fit.
Just to clarify and not to split hairssome of the rails are shaped to match the van profile from front to back and up and down VW T5/T6. There are different part numbers for each van. However, some rails are straight T4 for example but they can be bent to suit the van. Bear in mind however that even the pre bent rails are still screwed.
I really don’t see the concern with screwing - this is the correct way as the manufacturer intended. Of course, you can second guess these instructions at your peril!!
Good luck,
Ian![]()
