Remote folding mirrors
Yackers777
Hi
Just bought t6 caravelle it has the folding mirror function on the switch but they don’t fold when I keep my finger on lock button on key fob like my old t6 , is this something that has to be programmed?
Thanks in advance
Paul
What year is it ?
2018 onwards should do it as standard, its a weird link but one touch windows need to be working for comfort mirror folding to function so try the windows first and confirm if they go fully up and down without holding the button, if they dont then reset one touch windows by taking the window all the way down then holding the button down for a few seconds then take window all the way up then hold the button up for a few seconds and repeat for both sides, once one touch windows are operating properly then try the mirrors again with a long press on the keyfob lock button
What year is it ?
Hi
Thanks for reply , it’s a 2016 , my kombi that I sold was a 2018 and that did it so that’s right what you said yes they do go up and down with one push /pull , so I’m guessing it would have to be programmed then
Thanks again
Paul
Hi
Thanks again
Paul
Heres the instructions on how to do it
If its a MY16 van then it can be programmed to do it (production date from around 09/15 to 08/16 ish)
Hi
Thanks for your help , my mate is going to try it during the week
Thanks again
Ah brilliant thanks mate !! My mate going to do it during the week
What year is it ?
Thanks very much for this, it just cured my windows and the mirror fold on the key long press.
Potentially resurrecting a thread here but I have just taken ownership of a T6 2016, registered April ‘16
It has power folding mirrors and will not fold on the key.
I have enabled the coding in VCDS, including comfort close, reset the windows and still nothing.
What am I missing?
You could post your most recent unedited VCDS Autoscan and we shall find out.
Reactions: mmi
Cheers Robert - this is the full scan BEFORE I made the changes, but should show the module.
The folding mirrors were already checked, but I then selected comfort close. I have since checked again in case I forgot to accept the code, but it's lodged
Code:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 5F 61 69
VIN: WV1ZZZ7HZGH075028   Mileage: 82900km-51511miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GQ    HW: 03L 907 309 L
   Component: R4 2,0L EDC   X38 8440
   Revision: 22X38---    Serial number: 00000000000000 CVN: 8549B1AD
   Coding: 01194012232401080000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TDI01103L906019GQ 003006
   ROD: EV_ECM20TDI01103L906019FH_003.rod
   VCID: 0005AF889B0AD293C3-8054
   VINID: 9E606AAAA1D8A976001C500220B6DE9CD6
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H05 0132
   Revision: 00000000    Serial number: 43215000000152
   Coding: 307E4098256984830C750278A48A21D3390000
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 3F876C74A6746D6BFA-806A
1 Fault Found:
0397 - TPMS Warning
          C102D F0 [008] - Pressure Loss
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 186
                    Mileage: 71174 km
                    Date: 2022.06.15
                    Time: 19:49:04
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 14111513470300
   Coding: 01
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_LWSKLOVW25X 005001
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF9D170E1FEA463B1-802A
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 7E0 907 047 S    HW: 7E0 907 047 S
   Component: Climatic-T5   H22 0607
   Revision: 00001002
   Coding: 0000000003
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ClimaticT5 A01003
   ROD: EV_ClimaT5Basis.rod
   VCID: 3A711D60BD564843CD-806E
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090     HW: 7E0 937 090
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 321150289
   Coding: A0F4793A0A61349393284F646CEB8FF48DA0718960CC6D603204003F0800
   Shop #: WSC 02737 022 152027
   VCID: 68D597289B7A0AD36B-803C
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 251115 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 L    HW: 7E0 959 801 L  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8654
   Serial number: KU0KU004111553088791
   Coding: 1400B1
   Subsystem 3 - Part No SW: 7E0 959 802 L    HW: 7E0 959 802 L  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8654
   Serial number: KU0KU005111553094587
   Coding: 0400A1
   Subsystem 4 - Part No: 7E1 951 172
   Component: DWA-Sensor 00  001 0104
   Coding: 000000
   Subsystem 5 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
   Coding: 000000
   Subsystem 6 - Part No: 7E1 951 172
   Coding: 000000
   Subsystem 7 - Part No SW: 2H0 959 442     HW: 2H0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29150002352570095476
   Coding: A4FFFF
1 Fault Found:
03303 - Response Closing Status of Rear Left Door
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 192
                    Mileage: 66959 km
                    Time Indication: 0
                    Date: 2016.09.17
                    Time: 13:05:08
Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
   Part No SW: 7E0 919 475 M    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0205
   Revision: --------    Serial number: 32961528601412
   Coding: 118008
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_VW75XParkAssis4K 001008
   ROD: EV_VW75XParkAssis4K_001.rod
   VCID: 3C7D1B78B7627673DF-8068
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 7E0 959 655 D    HW: 7E0 959 655 D
   Component: VW10Airbag00J 008 0016
   Revision: --------    Serial number: 003PH001V6NK Dataset Number: 7E0003V____ 0737
   Coding: 00000000000000000000000000000000304A
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 377704548E44552B32-8062
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 7E0 920 970 L    HW: 7E0 920 970 L
   Component: KOMBI         H05 1008
   Coding: 470F010100
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
   VCID: 336F30449A3CB90B0E-8066
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 042305
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 7E0 857 511 F    HW: 7E0 857 511 C
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 010101E200000100000000
   ASAM Dataset: EV_HighBeamAssisAU316 001004
   ROD: EV_HighBeamAssisAU316.rod
   VCID: 2D5B263C7C18EFFB58-8078
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H05 1008
   Serial number:
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6AD1ED208D7638C37D-803E
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 1K8 035 150 E    HW: 1K8 035 150 E
   Component: MU-E-D-ER     857 6495
   Serial number: 28101500012854 Dataset Number: 5K7CV1v____ 0001
   Coding: 065700003C00000041111101008000001F0000860000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2757D4145EE4C5ABA2-8072
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0733
   Coding: 030B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
   Component: J367-BDM  H08 0223
   Serial number: 52308N36281261013590
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: ConWysTrailer H07 0100
   Revision: 3A001001    Serial number: 00000132425721
   Coding: 0100000100000000
   Shop #: WSC 00007 223 174336
   VCID: 30653F48632A821373-8064
