Open the slider and tailgate, you will see bolts at each end. Remove these and gently prise the cover off. Make sure you have about 7 of the plastic trim clips that hold it on as they will break.
Perfect, thank you!Open the slider and tailgate, you will see bolts at each end. Remove these and gently prise the cover off. Make sure you have about 7 of the plastic trim clips that hold it on as they will break.
Be careful its fairly thin metal and easy to bend,Perfect, thank you!
I can see the back of the threaded inserts on the inside of the panel so this makes so much more sense now.
I'll give it a go soon after ordering spare trim clips and take photos.
Thank you for the heads up.Be careful its fairly thin metal and easy to bend,
I can’t say I noticed any sound difference when closing the sliding door. Not as much as relubricating the rollers, anyhowI'm going through the process of adding sound deadening to my LWB Shuttle and I'm wondering what people have done in order to apply some to this panel:
It doesn't appear to be accessible from the inside and it's annoyingly tinny compared to the panels above and below that I've applied sound deadening to.
Can it be removed without damaging it?
Thanks,
Bunny
Seal with what? Can’t be too permanent in case the clips need to come out.If you can, seal them from the inside, I broke every clip taking that cover off to add sound deadening to it, the clips just shatter.
