Replacement abs module
patstone
Because my abs is damaged i can not get abs codes, is there another way to code new abs module . 2016 vw t6 t30 140hp euro5 caac engine
Nothing complicated! But you must give the previous encoding of your block, or fully describe your car's drive, gear selection mechanism, number of transmission steps, size of front brake discs, all-wheel drive, differential lock, ACC radar, and VIN
It sounds complicated to me never coded abs before all new to me,was hoping I would be handed a number and just stick it in, thanks for the info
Only other way with out existing code is ODIS
All you need is this VCDS. Post a full auto scan of your car, then you will need to answer a few questions and I will try to help you with coding
