Great thanks. I will order, try them and report back.
It's a small thing hyperflash, but gets annoying over time!
No, that is incorrect.
Your calculations would be perfect if you were planning to replace your original bulb with resistor onlyI've done my calculations:
P = U x I ---> I = P / U = 27W / 14.5V = 1.8620A ===> R = U / I = 14.5V / 1.8620A = 7.78Ω
So i think these would be fine:
RS PRO, 8Ω 50W Wire Wound Chassis Mount Resistor ±5% | RS
ie.rs-online.com
Oh i know Robert, i was venting at myself and not understanding the calculations properly, same with the hex coding and all that!I am trying my best to be as helpful as possible.
You need one resistor for each side and if your new LED bulb wattage is as per above than your calculations are now correct.
Maybe you should try Renault Trafic...
Why cant these vans just be simple.
I would go for 15ohm.Oh i know Robert, i was venting at myself and not understanding the calculations properly, same with the hex coding and all that!
so do i go:
RS PRO, 15Ω 50W Wire Wound Chassis Mount Resistor ±5% | RS
ie.rs-online.com
or
RS PRO, 18Ω 50W Wire Wound Chassis Mount Resistor ±5% | RS
ie.rs-online.com
HahhahaMaybe you should try Renault Trafic.
Hi @Robert This is what I do Know in Uppercase below.What's your 09BCM Byte 18 hex value?
What year is your van?
What headlamps have you got(H4, twin H7, LED)?
And what is the wattage of you new repeaters?
Will post first thing @Robert many thanks PaulCan you post photo of your head lamp and tail lamp?
Where are you based? I have vcds which is the program you need to get the information Robert asked in the first question. Im in Manchester if thats any use.Will post first thing @Robert many thanks Paul
Many thanks Sam, do appreciate the offer. Unfortunately I am near Stamford, Lincs. Many ThanksPaulWhere are you based? I have vcds which is the program you need to get the information Robert asked in the first question. Im in Manchester if thats any use.
@Robert here we go. Fyi. The double speed indicator fault happens whether turning R or L.Can you post photo of your head lamp and tail lamp?
