If like me you are taking off your electric without power fold mirrors to replace with power fold mirrors I've given info on the controller and parts I used earlier, here are a few extra notes.
Mirror cap removal and replacement needs care
You can see how they clip together from the new ones you have bought. I found it easier to remove the mirror glass to release the clips at the top, then work round with a narrow trim tool to release the bottom clips. I did snap a few catches on the old base trim but that was no problem as I was replacing those. At the end of the job when you refit the caps to the new mirrors make sure everything is lined up before pressing home.
Removing the various aerials from the old mirrors is fine (the black box one is on a sticky pad). On my replacement mirrors the cable hole through the central pivot was smaller. You can cut and re-join the aerial coax but my preference was to cut and slide back the sleeve over the other cables to give more room, remove heat shrinking on the aerial cables and bend their earth tags to a ‘C’ shape so that they would feed through, then slide back the cable sleeve, tape that up and tape where heat shrink was removed if necessary. Makes sense when you see it!
You will need to change your mirror switch and I got part 7E1 959 565K from my dealer. It has a chrome trim which the old one didn’t but that matches the central control dials so I’m happy. Here’s old and new,
View attachment 3512 View attachment 3513
(same colour, different lighting conditions!)
Phew, that’s about all! Ask if any questions
