Hi - just been fitting a reversing camera (Autovox V5 Pro) to my 2018 T6. While doing this I've removed part of the roof paneling and disconnected one of the rear interior lights (not sure if this is relevant). When I've tried to find the reverse cable to connect the reversing camera, I've found that neither the reverse light or the brake lights are working. The rear lights and indicators are are ok. As part of the fitting, I removed the front passenger seats (now refitted and reconnected) and piggybacked the unit to both a switched live and a permanent live fuse (as per the instructions). Again not sure how much of this is relevant.
Any idea what is causing the reverse and brake lights not to work? The battery also seems to be draining.
