Guys guys guys........at the end of the day it doesn't make a whole lot of difference - thin edge, fat edge....all that matters is Jimmi is happy with the look/outcome.
Sorry, that is incorrect. If you imagine sucking a drink through a straw, then the physics of what happens is you reduce the pressure on the surface of the liquid inside the straw, this reduces the downwards force on that part of the liquid. Now the air pressure on the surface outside the straw is much higher producing a larger force so pushing the liquid up the straw. It is not the reduced air pressure that pulls.You get more effect from the lower pressure sucking the wing upwards than the high pressure pushing it upwards.
Nature abhors a vacuum, it is easier to suck a bowling ball into the end of a vacuum cleaner hose end than it is to blow air under it to lift it up.
You’ve got that wrong. The big blue roof bar is meant to go across the van not front to rear. That will cause a sideways fluffle and will create time travel.View attachment 45186
They look wicked!
James Dyson and a few ladies I have known will tell you that you can suck things up.Sorry, that is incorrect. If you imagine sucking a drink through a straw, then the physics of what happens is you reduce the pressure on the surface of the liquid inside the straw, this reduces the downwards force on that part of the liquid. Now the air pressure on the surface outside the straw is much higher producing a larger force so pushing the liquid up the straw. It is not the reduced air pressure that pulls.
Actually James Dyson will tell you its impossible, Im sure the ladies might have a different view.James Dyson and a few ladies I have known will tell you that you can suck things up.![]()
They came with plugs for the holes, but I have to say the whole set up looks pretty cheaply made for OEM parts. The instructions were absolutely useless and badly printed on a bit of folded A5 paperAs an aside, did the oem bars come with plugs for the allen bolts? Not sure if mine did and I lost them in the packaging or there weren't any to begin with. Just look unfinished with the allen bolt heads still showing
Did it dry out ok?Just keep your eyes peeled for them leaking fella roof bars wrecked me last vanleaked all down the A pillars and into the dash and footwells.
