Found Roof rail blanking caps
do you mean the bolts in the van roof (below link) or the rubber cap that fills the hole on top of the OEM roof rails?
you can also use a stainless or galvanised M6 bolt with a roofing washer to do the same thing which may save a few quid
Hi....if you have a 3D printer @The_Lad has created this to print for the roof rails....I could print you a couple, for postage if you like.....
Many thanks, yes, that would be so helpful- just concerned about too much water ingress.
If you give me a shout when theyre done I'll paypal you the cost
