Hi everyone,
i'm hoping someone can help me please. i have a 2018 ex RAC DSG T6 euro6. i purchased slightly cheaper as when cold it had a rough idle and misfire when driving. also when cold it really stinks of unburnt fuel kind of smell. its not in the cabin its from the exhaust and only smells outside but its very strong. once its warm it runs perfect with no loss of power, missfires or rough idling or smell.
i had a fault on injector 2 when i first scanned it so had this replaced and coded. this has made no difference.
I've now been playing with VCDS and looking at some live data.
only thing that's really jumping out to me is when comparing the cylinder bank internal moment readings across all 4 cylinders. At idle it's pretty steady, all very close to 500nm. as soon as i hold the revs over 1000rpm cylinder 1,3 and 4 go to roughly 6000nm but cylinder 2 drops to around -10nm and stays while i hold the revs. fuel injection time deviation has no pattern and all 4 injectors wander between -80µs and +80µs at idle
i can post a video on youtube if it helps or if there is something else anyone can recommend checking?
i know there has been lots on the net with similar issues, I've tried the VW injector cleaner and another industrial one recommended by the garage. i know the previous owner had this diagnosed as DMF so he had this done a few months ago but again made no difference. I've heard of rods being bent by hydrolocking, i'm not losing coolant, however i do not know when it was an RAC van if it had issues and the EGR cooler replaced. it looks original to me and no obvious signs it's been done. I've read all the threads but i'm a little stuck now.
Thanks in advance
Thanks in advance
