That does mean there is minimal RCD protection on the 13A socket though if you're splitting before the 16A into your EHU, you're reliant on whatever is protecting the cable run at the post.I’’ve hardwired a split in my EHU cable at the van end. One goes to the van EHU, the other to an IP rated 13 amp socket in the awning (Or tucked away under the van if no awning).
Hmmm, and the EHU supply at the post is not obliged to include RCD I suspect?That does mean there is minimal RCD protection on the 13A socket though if you're splitting before the 16A into your EHU, you're reliant on whatever is protecting the cable run at the post.
^^^thisif its inside your awning then nobody needs to know
