So far so good!
Removing the cloth from under rear hatch rubber solved rear hatch leak.
Wet C post was rear NS window ( hidden behind a blind and frame hadn't noticed until I removed the blind and found the carpet soaking in the corner which was tracking across to the C post! Re sealed the frame on the inside, did the trick!
Poptop: found a company that supplies new seals on Hayling Island ( fairly local for me) difference was this seal has a small rubber lip just offset from middle of the "tube" about 2 mm in size, so when closed it seems to just add a little more of a seal!
3 nights of torrential rain and still dry! Windscreen a lot better as well especially as the inside is still a bit damp ! I live on a hill so have parked the van in both directions all is well!
Fingers crossed I can get on with updating the wiring and then rebuild interior!
