OK, here is where this going to confuse the hell out of some people. Varta may make an AGM battery that has the facility to fit a vent tube, many manufacturers don't. So, if you fit a Varta battery then by all means follow their advice and fit the vent tube. If however you have a SLA battery from Trojan, Yuasa, Leoch, Optima to name but a few you will find that there is NO facility to attach a venting mechanism of any kind.
If your battery has the facility to fit a vent tube then fit it. If it doesn't don't lose any sleep about it. The amount of gas likely to be released is very tiny and would dilute in the atmosphere inside the van to insignificant levels.
The pressure relief valve on these batteries is set at 5 psi so it's not as though you are going to get huge jets of gas emitting from an overcharged battery! The reason that the Touareg has a vent tube is because the battery is fitted in a very enclosed space, the same could be argued for a factory fitted aux battery in a T4/5/6 with its rubber cover. Aftermarket installs do not have such an enclosure. Battery sheds for solar installations are very often crammed full of AGM batteries and will have less free air than the inside of a van but no venting of individual batteries.
I'm not stuck in the mud, I just base my comments on 50 years of experience working with batteries. Anybody have any stories of batteries exploding in vans?
