Hi, I’m currently installing second row seatbelts, I have had to cut a hole in the 3.6mm trim to bring the seatbelt out from behind the trim, the seat belt plastic trim that clips into the opening won’t clip into place as the ply is to thick. So do you not use 3.6mm ply for this panel? Maybe trim back couple of layers of the ply? Or something else? Any suggestions would be helpful for this newbie
