Sections of wiring loom found on floor
Zorb
Hi everyone, does anybody recognise this loom? I moved my T6 2016 Caravelle and this was underneath it! Can't help thinking it's not a good thing. Drove fine last time I used it.20220326_113224.jpg
Do the ends look chewed - could be mice or rats ?
Can’t help with what it is.
Pete
Hi everyone, does anybody recognise this loom? I moved my T6 2016 Caravelle and this was underneath it! Can't help thinking it's not a good thing. Drove fine last time I used it.View attachment 150758
  • Wow
Looks like foxes having a chew, common problem. Do you get an adblue fault on the dash?
Have you driven it yet ?
Might need to drive for a couple minutes before things like adblu problem shows
No I haven't driven it yet, thought I'd see if anyone knew the wiring colours first, just in case it was anything serious that could cause damage.
When I first noticed I had my cables chewed through I had a stop start warning light on. The picture below was the one I took at the time, I think you can just see the cables chewed through are brown plus a blue and white one like yours, I suggest you crawl underneath and have a look, you need to go in line with the back of the front wheels, there is also a thread on here on rodent damage
Surely both sets of those wires are white and blue not blue and white? Need to know what you are looking at on a wiring diagram.
The point I was making is the cables I had chewed through look the same colour as the OPs so it’s worth checking under the car in the same location
Having the same issues as above... suspected foxes as I seen a few of them playing around my van last week ;(
I have made a temp repair to the loom with some soldering and heartshrink.
I reset the everything on carista but my oil light is still flashing yellow and my start stop isn't working. Is there a fuse specifically for the oil sensor??
I didn't see any other wires damaged underneath but looks like I will need to get under again for a good inspection.
I have sprayed a water / vinegar solution under the van to hopefully stop further intrest.
