I guess soAs I said in my post if somebody wants it that bad they’ll have it.
Right I have the wheel and carrier ordered... But now I have to source some stainless steel pipe. What diameter did you use?17" wheel now on the carrier. I hade to drop the carrier down to it's lowest setting. I then bought 2 x security bolts, each one having different setting on their sockets for removal. I also bought a security shroud to put one of the security bolts through. I tightened everything up so that the wheel was snug but the tyre wall was not compressed. I then measured the distance of the thread showing on the security bolt, removed the bolts, cut 2 sections of stainless steel pipe to the measurements of the showing thread of the security bolts. I then greased the threads and re- fitted the security bolts, pushing them through the stainless pipe section, ratcheting them up into the carrier until the heads were solid up against the carrier and the sections pipe were compressed tight. I live in hope that the visual appearance of the shroud which is bright red, the 2 sections of pipe preventing access to the threads and the bolts each needing there own individual socket to undo them. A person can only do so much and I realise that given enough time and opportunity my spare wheel carrier with never be 'Scrote Proof'.
Brand | CampervanBits |
Material | Alloy Steel |
Finish type | Powder Coated |
Lock type | Key Lock |
See this thread for info:Just need to get a jack now! I have read on the forum the VW Jack's are not great. Any recommendations, needs to be small and only for emergency use.
Thanks for the confirmation.The thread is M12 x 1.5 x 52
Hope this helps.
If you go onto e-bay and search the security bolts anti theft for VW Trsnsporter you will see the security bolts, go into description and it will give you the thread size as confirmation. Feel free to look up my post on 'Spare Wheel security'. I also went up from 16" wheel to 17".
The security bolts for the spare wheel on mine I bought off E-Bay. I was able to buy longer than standard bolts that allowed for me to engage the bolts through the carrier with a larger spare wheel in place.Thanks for the confirmation.
I’m using an 18” spare and don’t want to butcher the carrier arm to fit. I’ve adjusted the front of the carrier arm to the lower option so need to add longer bolts at the back with 30mm spacers for the wheel to fit. Spacers or a sparesafe device.
What size spare are you using? Your set up looks to be the way to go for me too.The security bolts for the spare wheel on mine I bought off E-Bay. I was able to buy longer than standard bolts that allowed for me to engage the bolts through the carrier with a larger spare wheel in place.
