gotcha,
yes option 2 is ok.
and yes the RENOGY DC50S has the "Auto VSR feature"
so when parked with engine off. . . you connect the Victron EHU charger 12/30/1 - via your 40A fused Anderson SB50 connector.
it will start charging the starter battery,
when starter battery rises above 13.8v or so,
the Renogy dc-dc will switch on and start charging your LB.
the Victron is a great charger for this setup as you can "tweak" the charge voltage. . . as in some chargers have some volt drop over the connection, and the dc-dc charger wont kick in, with the Victron you can tweak the charge profile and UP the charge voltage a bit.
i show it in action over here:
@Farnorthsurfer did you set the Dc-dc to lithium mode for the TN100 battery? Also have you got any more BM2 views showing more days? Yes the unit is set to Lithium profile. Easy enough to do when it was powered up. Yesterday was a flat line all day as it just sat on the drive. Back to work...
www.t6forum.com
engine OFF, and charger plugged in. . .
Renogy DC-DC sees voltage rise, and turns on - which starts charging the LB.
both batterys get charged,
