Short circuit fuse C44
Dibbus
I would like some help on this issue.
I have a T6 from 2016, with 6 doors: 2 front doors, 2 sliding doors and 2 backdoors.
The van has NL-plates and lefthand drive.
The central locking is not working and fuse 44 in fusebox C keeps blowing.
According to the schematics, there is a red/blue wire to junction A194.
1st Question: where can I find this junction?
from there 5 wires to: T17j, T10q, T10bk, T10f and T73a
2nd question: where can I find these connectors?
Finally I would like to know where the following units are located:
J605 (rear lid control unit), J558 & J731 (sliding door control units) and J519 ( onboard supply control unit).
many thanks in advance.
greeting,
Jan,
Wire joins are in the loom and not accessible, they are taped up inside the main wiring runs and notoriously difficult to find/fix, they should be left as a last resort, you would be better off finding and disconnecting/testing all the wires further downstream from the join and hopefully you will be able to prove or disprove the location of the short
Any Txx number is a wiring connection point where xx represents the number of wires in the plug/socket
If you look at the legend on that specific page of the wiring diagram the list should state the corresponding T number followed by the colour of the plastic plug housing and the approximate location
Rear lid and sliding door control units are located inside the rear quarter panels, they are fixed on a metal bracket each side that screws into the back lip of the wheel arch
J519 is the body control module often referred to as BCM and is located above/beside the pedals
T17j 17-pin connector, white, under seat on front left
T17q 17-pin connector, black, under seat on front left
T10bk 10-pin connector, grey, under seat on front right
T17f 17-pin connector, brown, under seat on front left
T73a 73-pin connector, black, in module J519 BCM
what about the location of T10q and T10f?
I assume under the front-right seat?
Or a better question might be: where did you find / where can I find the data for the locations?
Many thanks.
Jan.
above/beside the pedals?
is that for the LHD the same as for the RHD?
so in my van the BCM is on the left side. correct?
Correct.
Page 805/47 below
Correct.
Page 805/47 below
many many thanks.
I will dig into the van and hopefully find the short.
grtz, jAn
