Better pic.
Wolfrace Munich's ! The silver and dark contrast looks great with the sidebars / roof rails too
Better pic.
@timthetinyhorse I'm not sure if you discounted this thread or just didn’t find it but there are plenty of photos here, so I’ve merged them.Im nearing the end of my wheel project however worried the van is going to look like a monster truck if i put my wheels on without lowering......has anyone go a pic of their wan on 20s with stock suspension?
Thanks for that, sorta put my monster truck worries at bay a little!! what tyre spec is that? like the front rake look also.Before the Steve's @ CRS Performed their Magic! running on 20" LV-2 Gunmetal Polished Face Alloys
During The Shock Treatment.....!
After 40mm drop on front 10mm on rear...!
Why.........! Plus side benefits....
Downside.....!
- Noticeable smoother ride
- Better handling
- Quieter
- Practical to carry tools
- Practical to tow a Caravan
- I like the A-Team look (without the red stripe)
- The front sensors are driving me mad, need to find a way to adjust sensors? any suggestions? welcome
- Paranoid about shredding front splitter...!
To me, that looks much more rake than CRS usually put. This could be giving you the issue with the front sensors. Possible solution - lower the back to a more normal rake.Before the Steve's @ CRS Performed their Magic! running on 20" LV-2 Gunmetal Polished Face Alloys
Downside.....!
- Better handling
- Quieter
Tim The tyre spec was an ill advised Leighton spec of 275/40R20 all around, but with the staggered set up, I find out after purchase..... the fronts should of been 255/40R20 I cant get matching tyres now so will change next time as they are T32 weight rated tyres, and I can only find 2 makes of tyres available to be road legalThanks for that, sorta put my monster truck worries at bay a little!! what tyre spec is that? like the front rake look also.
Thanks Skyliner Steve did say he would change the ride height if their were any issues its been a few weeks and this is an issue for me, if there is no way of tweaking the sensors this is the way forwardTo me, that looks much more rake than CRS usually put. This could be giving you the issue with the front sensors. Possible solution - lower the back to a more normal rake.
Cheers for that, what width? Mine are 8.5 and been recommended I go for a 255-40-20Tim The tyre spec was an ill advised Leighton spec of 275/40R20 all around, but with the staggered set up, I find out after purchase..... the fronts should of been 255/40R20 I cant get matching tyres now so will change next time as they are T32 weight rated tyres, and I can only find 2 makes of tyres available to be road legal
I’m fairly level and my rears (I don’t have front PDC) do the same whenever I reverse over a severe camber in the road / towards my dropped kerb.The front sensors are driving me mad, need to find a way to adjust sensors? any suggestions? welcome
Specification:Cheers for that, what width? Mine are 8.5 and been recommended I go for a 255-40-20
Thanks Ads I will investigateI’m fairly level and my rears (I don’t have front PDC) do the same whenever I reverse over a severe camber in the road / towards my dropped kerb.
I was suggested these sensor angle adapters to offset the angle (note that these may not be the correct size
