True, it seems to be more susceptible, either up near battery or underneath in the poorly protected and routed conduit. I’ve absolutely no doubt other wires will get damaged in the same area over time. They are pull back and forth to several clamps, and then many wires that exit are not protected, example, egr and charge cooler pump wires simply exit the conduit and are exposed.It does seem odd that it's always the LIN wire, you'd think it would be others with similar routing or from the same supply chain.
