Sold Sliding door power latching retrofit kit
hunta
Used kit purchased from Pauly for the passenger side sliding door of a 2016 T6 Kombi as featured in the thread linked below, but realistically I'm not going to get around to fitting it.
Looking for £300 plus postage, or collect from South Bucks.
Would this be suitable for my T5.1 LWB? I think the thread suggests I'd need a longer wiring loom at least.
I make the looms a slightly different length to accommodate SWB or LWB so the motor cables will prob be a touch short
Assume these kits aren't 'handed', i.e. this would work for the driver's side slider on a T6 California?
The motors are handed so would only work on the side it’s intended for but I could do you a kit for the other side if you want one ?
Pm me if you want to discuss
Hi @Pauly @hunta can the cables not be run down the pillar and under the side step to passenger seat? I have a lwb and am interested in this kit as had enough off slamming the door.
Excuse my ignorance, but is this just a soft close kit ?
Yes the cables can be run low instead of over the roof but its the link cable from module to motor that would be short
I still do these kits so can make LWB versions if your after one
