this is helpfulThe manual should indicate cable and fuse size. Size fuse to protect cables, depends on installation method and type of cable, but 4mm will be around 40A (likely more in real life), so I'd put a 35 or 40 a fuse in. See Here
same principle applies. If the Renology is outputting 50A, you need to size cables to carry 50A minimum and then fuse smaller than cable capacity so fuse 'blows' before cable burns out. There are other factors to take into account on cable size, volt drop, installation method, diversity etc for cable sizing (all affects current carrying capacity) but no need to go into all that here.this is helpfulalthough i meant the fuses from the renogy unit to the car and leisure batteries
im assuming 60AH for the 50A DC unit. will go through manual later
iam using a multimeter to correlate the readings on the battery, the monitor and the Victron MPPT not just taking the readings for granted. WeirdYou're assuming here that both measurements are correct, it might simply be that one of them isn't accurately calibrated.
What MPPT are you using?
This is my next job @dcpen43, I've read and read loads on here and it seems a pretty straightforward job adding the Mppt. I don't want mine to be permanent so intend to just have the connects so I can hook it up when needed.Finished my solar fit today with the cables fed outside the habitation area to two predrilled grommeted holes in the RHS barn door cill. No idea what their original purpose was. Cables feed above the wardrobe and along the back of the rack and pop out just before the drivers B pillar. My Victron MPPT is mounted behind the driver's seat allowing a short output run to the LB under the driver. All working good.
On your point about heaters. Got a tip to but a small AC Ceramic heater so that I don't need to burn my diesel when on EHU.
@roadtripper thankyou for taking an interest in this.Do you have a diagram of your setup?
You mention a cable run of 1.5m - is that between the Main Battery and MPPT?
What cross section is that cable? And what charge current? Might be interesting to work out what the voltage drop would be.
The mental map I have from your description is this:
BM6 <-> Main Battery <-> Inline Fuse <-> 1.5m cable <-> Victron MPPT <-> Panels
no its a Heschen switch and i have to physically plug the sae cable into the port. anyway took some readings today. 13.46v at the MPPT and in line fuse so negligible volt drop attributed to AWG10 cable. 12.42v on the battery side of the in line fuse.If you have a changeover switch like that you might also want to double check it is a "break before make" otherwise everytime you change over there is a moment where you are directly connecting both batteries and with a big differential you could get substantial current flow.
There isn't a van BMS in a position to control any charge (it does that simply by controlling the alternator) and your cable goes direct to the battery.
Have you checked the voltage at the terminals of the MPPT when everything is connected? I can understand why it would be a different voltage when it's just floating and not connected but not otherwise.
You still haven't mentioned the charge current but an estimate of 1v drop at 5a is a 5w loss, so about 0.2ohms, that seems high but not impossible and wouldn't really warm things up. With 10awg over 1.5m though the expected drop would be about 0.05v
I'm wondering if you have a bit of corrosion or something not seated right in your run, 0.2ohms isn't a lot in those
first thing i did was to check the MPPT direct as in the pic to give me a volt drop reference. Charge current lowThere isn't a van BMS in a position to control any charge (it does that simply by controlling the alternator) and your cable goes direct to the battery.
I'm wondering if you have a bit of corrosion or something not seated right in your run, 0.2ohms isn't a lot in those conditions
ok my choice of words. the ECU is actively preventing charge to the battery based on SoC? if you dont use the battery for the starter motor etc often then charge capacity is adapted to extend battery life?Yes the van ECU tracks the state of the battery at all times via the negative shunt but it has no way of actively limiting the charge - it has no need to as the only charger it knows about is the alternator. If it doesn't think the battery needs charge, it doesn't enable the alternator.
yep but the VCDS will tell me what data the ECU is holding on the battery and as the attachment shows the garage did not do any codingThere is nothing in the van electrics or any setting in VCDS that will actively stop the starter battery charging from your MPPT.
How your MPPT behaves is solely a function of the MPPT settings and the wiring between it and the battery.
