D
Deleted member 6336
Guest
Hi all,
I’m hoping some of you solar gurus can help with a problem I’m having with my converted T6 campervan.
My set up which has worked perfectly for the past 2.5 years is:
Battery:
On our last trip away, back in April before it warmed up we got a low (leisure) battery warning so apparently we managed to deplete it overnight. The load was 1x 12v fridge, 2 x iPads charging and 2 x iPhones charging. *As per my earlier comment, this is generally the load we put on the battery overnight and had no low power issues.
I carried out a basic discharge test on the battery, disconnecting the fully charged battery from the panel and it took around a day and a half for the battery to discharge from 13V to 11. 7V and trigger the warning.
It’s a little dometic 12V fridge, but unfortunately I don’t know the advertised power usage, but I would have expected around 2-3 days.
Q1: Do you think the battery is on its way out and needs to be replaced?
PS, I’ve already been down the rabbit hole of lead acid vs AGM vs Gell, vs lithium!! Ultimately the quality of battery I get will depend on the outcome of Q2
Solar charging:
I‘m lucky to have a friend with a lot more knowledge on solar and van builds than me but he is cray busy, so all he can manage is to drop in now and then on his was home from work.
Has has tested the output from the solar in optimal conditions (unusual for Scotland) and we are generally only getting around 11V from the panel. We have seen as much as 16V but on re-testing get around 11V again, so this is weird.
From my layman knowledge, I understand that the panel will not charge the battery if the voltage of the battery is higher that the output from the panel, so this explains why the battery is never getting charged from the panel.
That is except for in some cases it does kick in, then stop. I have just turned the fridge on with the battery sitting at 12.9V and the solar panel indicator light on the CTEK unit came on for awile (I didn’t sit and watch it) but it was less than an hour.
We have removed the Photonic Universe MPPT to see if it was faulty and disrupting the flow to the battery but it has made no difference.
If you’ve made it this far, thanks for sticking with me even if you don’t have a clue either
Colin
- Photonic Universe 120W semi-rigid panel
- Photonic Universe MPPT charge controller
- CTEK D250SA DC-DC charge controller
- 90AH lead acid battery (2.5 years old)
Battery:
Solar charging:
- The panel has no obvious damage to explain the low/intermittent output.
- My mate has tested the voltage at the panel junction box and at the battery to rule out wiring issues
Colin
