They may be on the same fuse but switched from the BCU, have you checked at the connectors on the BCU?
Thanks will checkThe RH tail light is a grey/red wire through that plug.
Stop light Black/red
Indicator Black/white
So do both rear lights connect to the same green connector as the grey and red wire is showing 12 volts but when disconnect the plug it turns the left rear light offThanks will check
Don't blame you TBH, hope they get it sorted.I'm not waisting anymore time on it put into the dealer they can deal with it pretty ridiculous having electrical faults with 12 k on the clock. Thanks for help much appreciated
Glad to hear it’s sorted.Rear light fault fixed, Van was in VW and they couldn't find the fault as the van is converted to a camper they didn't want to start removing any panels or units as I would of been charged labour, they were very helpful and advised I check the wiring loom, anyway problem found a split cable in the roof wiring loom ( the one that runs accross below the roof brake light) VW still need to sort the abs light. Have to say they were very helpful, thanks for everyone's help on this much appreciated.
@Spaghetti was on the money. It’s happened to others who’ve had conversion work - I think the last was a drop-out in the reversing camera.I presume all the wiring had been checked? Have you tested the connectors to see whether there is any power at the connectors? Has the van been converted and sustained any damage to the wiring?
