R0n1n
Discovered today that cannot run EHU/split charge cabling through the 'usual' grommet behind the starter battery as my van has a sunroof and that's where a drain pipe grommet is fitted.
Only other holes I could see (no grommets) fed in to the wing.
Removed the battery tray as some cables disappeared under the tray but they disappeared in to the side of the van out of sight (couldn't see or feel for a grommet there either).
I've tried using forum search but haven't found the same issue (so far). I'm hoping I've missed another obvious way in..?
