If it's charging the leisure battery is the van either running or the starter battery on a charger?
starter on charge, must be really low as charger ( old one) clicking on and off so not enough charge yet to keep onIf it's charging the leisure battery is the van either running or the starter battery on a charger?
Maybe not Ablemail then as continuous red light on?
Thanks for that, at mo still charging starter battery and not enough to crank yet (10.2v). Notice light on dc to dc charger still on solid red? Should this go green when all is good?I’m positive you have an Ablemail 12-12-30. It would be worth dropping Jonathan an email at info@ablemail.co.uk
Yes took van to my conversion man today and he was stumped as well. He contacted Johnathon at Ablemail twice and the upshot was he thought it was knackered.I don’t know what solid red means as the instructions only refer to a flashing LED which is either red, amber, or green. I would ask Jonathan at Ablemail as it may have something to do with why your starter batt is draining.
Yes understood, I keep calling it relayOnce again there is no relay in your system, you have a DC-DC charger. A relay just connects two switch contacts together, a DC-DC charger takes DC in from the starter battery, transforms it to high frequency AC and then transforms that to the exact DC voltage required by the leisure battery at that point in the charge cycle.
The white tails on the negative starter terminal are to do with the tow bar. I took it to another towbar fitter and they assured me it was fitted correctly (wiring 2 option) they also told me that the block on the negative post was to do with the start/stop function only. I'm even more confused now.Once again there is no relay in your system, you have a DC-DC charger. A relay just connects two switch contacts together, a DC-DC charger takes DC in from the starter battery, transforms it to high frequency AC and then transforms that to the exact DC voltage required by the leisure battery at that point in the charge cycle.
If your converter is changing over the Ablemail I would also ask them to move the grounds off the starter battery terminal as advised here and in the original thread. I fear otherwise you are going to be eating batteries.
Understood re the towbar module staying awake and I have now learnt from that, Thankyou.The towbar fitter is wrong and doesn't understand the function of the current shunt. VW are very clear about not connecting directly to the negative post even when jump starting or charging.
You have a towbar electric system fitted that bypasses the battery monitor, you also mention you leave your bike carrier electrics plugged in. That sounds like a classic parasitic drain if the towbar module stays awake and that drain will not be seen by the van so it will not put it back.
Your towbar has been fitted very tidily, the wiring and crimp work looks very good, but it is using the wrong ground.
Yup, 6 week road trip starting Monday, France and Spain.Glad you got it sorted - and you now know a useful bit more about your van
I wouldn't obsess with monitoring but it's useful to get to know the ebb and flow of energy in your van the way you use it - will allow you to spot anything "odd" and investigate.
Now the important thing is to get out and enjoy it before winter is upon us![]()
