sporadic heater plug warning light issue
FAC51
Happy new year to the forum.
I have a sporadic heater plug warning light issue which has proved to be somewhat annoying.
All of the plugs have been changed
NO fault codes appear
but the light continues to go on and off sporadically and I've a few thousand miles to cover in the next month
Should I be worried and does the forum have a solution to this issue
Thank you
fully compatible large garage code reader
Engine running
Only comes on and off whilst driving within minutes
Several times within every journey
Flashing light
No loss of power
Reactions: mmi
Try cleaning the leads. Had the coil light come on. Plugged it in and came up plug 4 was down. Cleaned all the contact points and all is good now. HTHs
Yep even an idiot like me can do it. It's just like a spark plug lead so dead easy. Mine had worked lose or wasn't fully push down when I had a new engine fitted.
