SeeHi
After speaking to Oli at Bognor Motors he has recommended ST Coilovers by KW
Is anybody else using them
Any comments good or bad
Cheers Oli your time
Andy
Welcome to the forum! Yes, exactly that. ST X.Hi everyone, new here so please be kind. Did tons of reading so far on forums, google and YouTube trying to learn as much as I can on Transporters. Planning to buy one in the next couple of months.
So my question is : is this coiler being discussed here the same as "ST X COILOVERS"? I'm trying to find coilover kits here in Australia for the T6.1 and I think I can find this model here
Thanks mate!It really is the best value and performing coilover kit on the market for T30 or less - it’s a KW v1 in a galvanised body instead of stainless. It doesn’t go as low as some, but low enough.
You can go to an ST XA if you want damping adjustment. This is a KW v2 - same as above
Could the same be said for a t32? My ride is shocking and I’m in the early stages of researching my options.It really is the best value and performing coilover kit on the market for T30 or less - it’s a KW v1 in a galvanised body instead of stainless. It doesn’t go as low as some, but low enough.
That’s a shame after what I’ve been hearing about them (and a few posts on b14 reliability?).ST Suspenison don't make Coilovers for T32, so we would be looking at B14 Komforts or KW V1
Are you local to me?
The KW V1 is essentially the same as the ST X, the major difference being the front shock bodies are stainless steel rather than lacquered galvanised steel. The internals are the same so the ride quality is just as impressive. The KW V1 is more expensive than the ST X, but a good way cheaper than the B14 komforts with better quality components too.That’s a shame after what I’ve been hearing about them (and a few posts on b14 reliability?).
yes, pretty local, Waterlooville, near Portsmouth, so you’re definitely my closest expert
Nice one, thanks for that, I’ll have a read.The KW V1 is essentially the same as the ST X, the major difference being the front shock bodies are stainless steel rather than lacquered galvanised steel. The internals are the same so the ride quality is just as impressive. The KW V1 is more expensive than the ST X, but a good way cheaper than the B14 komforts with better quality components too.
no problem. I should add that the B14 komforts have an additional 5mm of lowering available compared to the KW. KW is 35 to 65mm. B14 komfort is 40mm to 70mm.Nice one, thanks for that, I’ll have a read.
Nice one, I like the idea of the test drives of the various set ups, but I reckon best bet for me would be taking you out in my van to show what it's like, then see what you'd suggest for itAs a direct comparison, the B14 Komforts actually sit a bit lower than the suggested 5mm. And it all about van weights and vehicle set up.
We stock all of the above suspension (when all the couriers catch up ) and run demo vehicles for the setups too, so you can come and compare directly
